What's new?
Connection information:
Check if the mobile server is accessible from the internet. See Connection information.
Alarms:
Add Emergency Alert alarms to enable the users to receive alarm notifications of the highest severity level in the XProtect Mobile client. See Add Emergency Alert alarms.
Bookmarks and live video sharing:
To share bookmarks and live video in the XProtect Mobile client, you must enable encryption on the management server. See Requirements for using Share.
Notifications:
You can remove device registration data from the VMS database. See Remove one or all registered devices from the Registered devices list.
External IDP:
You can now log in to XProtect Web Client and the XProtect Mobile client with an external IDP. See External IDP and XProtect Mobile
Mobile device management (MDM):
The XProtect Mobile client now supports mobile device management (MDM). With MDM, you can manage and secure devices, apps, and data from a unified console. For more information, see Mobile device management (MDM)
Push notifications:
When you enable this feature, a warning informs you that your system may not be GDPR-compliant
Notifications:
Notifications are disabled by default
Installation:
When installing Mobile Server, you can connect to the surveillance system with a basic user
