Requirements for direct streaming
XProtect Mobile supports direct streaming in live mode. To use direct streaming in XProtect Web Client and XProtect Mobile client, you must have the following camera configuration:
The cameras must support the H.264 codec or the H.265 codec.
The XProtect Mobile client supports H.264 only.
- It is recommended that you set the GOP size value to 1 second, and the FPS setting must have a value that is higher than 10 FPS.
