Requirements for using push-to-talk
To use the push-to-talk (PTT) feature on your mobile device in your XProtect VMS, you must have:
- Cameras that have speakers attached.
- Sufficient user permissions.
Access to the push-to-talk feature may be restricted depending on your user permissions. Ask your system administrator if in doubt.
- Allowed the XProtect Mobile app to use the microphone of your mobile device.
HTTP or HTTPS with CA certificate connection.
If you want to use an HTTPS connection, a digital certificate from a certificate authority (CA) must be installed on your XProtect Mobile server.
