Changing the grid layout on tablets
If you use the XProtect Mobile client on tablets, you can adjust how the app visually represents the cameras by changing the grid layout for cameras. Depending on whether you're in portrait or landscape mode, you can choose between one, two, or three columns.
To change the grid layout, go to the specific view, tap the grid icon in the upper-right corner, and choose the grid layout you need.
You cannot change the grid layout on smartphone versions of the XProtect Mobile client.
