Introduction
This document describes how to install and maintain the XProtect Input Unit Plug-in for Panasonic WV-CU950 Controller in XProtect Smart Client. This document assumes that you know how to operate the Panasonic WV-CU950 Controller.
A full description of the Panasonic WV-CU950 Controller is available in a document titled WVCU950.pdf, which installs on your computer when you install the XProtect Input Unit Plug-in.
