Introduction
This document describes how to install the XProtect Input Unit Plug-in for the Axis T8310 Video Surveillance Control Board in XProtect Smart Client. This document assumes that you know how to operate the Axis T8310 Video Surveillance Control Board - in the rest of this document referred to as "Axis T8310".
A full description of the Axis T8310 is available in a document titled ug_T81series_38417_en_1002.pdf, which installs on your computer when you install the XProtect Input Unit Plug-in.
