Recovery
You can do a recovery on your Milestone Husky unit, which resets your unit to the factory default state and lets you start over and reconfigure your unit from scratch.
Recovery will:
  • Reset your Husky unit to the factory default
  • Run Husky Assistant wizard to configure your unit
  • Help you install Milestone XProtect
All data on the Windows (C:) drive will be lost, and your XProtect system will not record any video during the recovery of your unit. You can save the Milestone XProtect VMS configuration before you start the recovery.
Data on the Data (D:) drive will not be deleted.
For detailed feature descriptions and procedures for configuration and maintenance, see the administrator manual for XProtect VMS.
Before the recovery process:
  1. Contact Milestone support to get the latest recovery software.
  2. Get help from Milestone support to create a bootable USB flash drive.
  3. Connect the USB flash drive to your Milestone Husky IVO unit.
  4. Prepare the BIOS settings to boot from USB flash drive.
To start the recovery process:
  1. Restart your unit.
  2. Boot from the USB flash drive.
  3. Your unit boots into recovery mode. Follow the instructions to complete the process.
Enter the Windows product key if prompted during the process, see Turn on the unit. For more information on first time use, see Complete the Husky Assistant Wizard.
