Test your Smart Wall configuration
After configuring XProtect Smart Wall in XProtect Management Client, you may want to test the configuration before you start adding the Smart Wall control to your views in XProtect Smart Client.
You have created at least one preset, assigned it to a monitor, defined its layout, and added at least one camera. See also Create presets for your Smart Wall definition or Define view layout and add cameras.
Steps:
- Log in to XProtect Smart Client.
- In the Views pane, expand the Smart Wall node.
Select a Smart Wall definition and then one of its monitors. If correctly configured, the main view shows the cameras that the preset
A predefined layout for one or more Smart Wall monitors in XProtect Smart Client. Presets determine which cameras are displayed, and how content is structured on each monitor on the video wall. is configured to show.
The example shows a monitor with two cameras.
