User permissions for Smart Wall (explained)
The settings described in this topic pertain to Roles in XProtect Management Client. To set the user permissions for all Smart Wall definitions, go to the Overall Security tab. To set the user permissions for specific Smart Wall definitions, go to the Smart Wall tab.
User permissions that apply to all Smart Wall definitions
Roles > Overall Security tab > Smart Wall
Specify user righs for all Smart Wall definitions on the roles.
Security permission
Description
Full control
Enables the permission to manage all security permissions in XProtect Management Client.
Read
Enables the permission to view a video wall in XProtect Smart Client.
Edit
Enables the permission to edit properties for the Smart Wall definition in XProtect Management Client.
Delete
Enables the permission to delete existing Smart Wall definitions in XProtect Management Client.
Operate
Enables the permission to activate and modify Smart Wall definitions, for example to change and activate presets or apply cameras on views in XProtect Smart Client and in XProtect Management Client.
You can associate Operate with time profiles that define when the user permission applies.
Create Smart Wall
Enables the permission to create new Smart Wall definitions in XProtect Management Client.
Manage security
Enables the permission to manage security permissions in XProtect Management Client for the Smart Wall definition.
Playback
Enables the permission to play back recorded data from a video wall in XProtect Smart Client.
You can associate Playback with time profiles that define when the user permission applies.
User permissions that apply to specific Smart Wall definitions
Roles > Smart Wall tab
Set user permissions for specific Smart Wall definitions on the roles.
Through roles, you can grant your client users Smart Wall-related user permissions:
Name
Description
Read
Allows users to view the selected Smart Wall in XProtect Smart Client.
Edit
Allows users to edit the selected Smart Wall in the Management Client.
Delete
Allows users to delete the selected Smart Wall in the Management Client.
Operate
Allows users to apply layouts on the selected Smart Wall in XProtect Smart Client and to activate presets.
Playback
Allows users to play back recorded data from the selected Smart Wall in XProtect Smart Client.
