Preview live video from multiple cameras
You can preview live video from up to 25 cameras on a smart map at the same time. To view the recorded video, you can send it to a new floating window.
  1. Select the smart map and find the cameras to view video from.
  2. Select the cameras using one or more of these methods:
    • Press and hold the CTRL key at the same time as you select the cameras.
    • In the toolbar, first click the Select multiple cameras icon , then select and drag to select the cameras within an area.
    • Double-click a cluster icon to zoom in and select the devices and potential sub-clusters inside the cluster.
    • Select at least one cluster to select all cameras in the clusters in one go.
  3. Right-click any of the selected cameras or clusters and select Live preview, or press Enter.
    Menu for a cluster after a user right-clicked the cluster.
    Live video feed from a camera after the camera was double-clicked.
  4. To play back and investigate the video in more detail:
    • In the Preview window, select Independent playback.
    • Or, in the Preview window, select More, Send to window, and then New floating window.
