Go to a device on your smart map
If your system administrator has specified the device’s GPS location, you can go to the place on the smart map where the device is and view it in its geographic context. This is useful if, for example, you forgot the location of a device or if you want to check nearby devices.
You can go to the device in two ways.
From the Views pane:
  1. Open the Views pane.
  2. Search for the device. If the device exists, it’s shown in the search results.
  3. Place your mouse over the device to go to it.
  4. Select to go to the device. The smart map opens in a floating window.
From the camera toolbar:
  1. Select the view and the view item that contains the camera to go to on the smart map.
  2. From the camera toolbar, select to go to the camera.
    Locate specific cameras on your smart map.
