Enable Milestone Map Service
Milestone Map Service is an online service with which you can connect to a tile server of Milestone Systems. This tile server uses a free, commercially available map service.
After you enable Milestone Map Service on your smart map, the smart map uses Milestone Map Service as its geographic background.
If the Milestone Map Service field is grayed out, you don't have the necessary user permissions to enable or disable the service. Contact your system administrator to help you enable the feature in XProtect Management Client.
Milestone Map Service requires internet access.
Steps:
On the global toolbar, select Settings and more
and then Settings
- In the left section, click Smart map.
- In the Milestone Map Service field, select Available.
- Click Close. Next time you load your smart map, it uses Milestone Map Service as the geographic background.
