Show or hide device information
You can show or hide information about devices on a smart map. This is useful, for example, when you want to increase or reduce the amount of content on your smart map.
- Select the view that contains the smart map that you want to work with.
- Click
Show or hide layers and custom overlays. - Select or clear the check boxes for the information to show or hide.
