Ports used by XProtect Incident Manager
The XProtect Incident Manager web service and server components use the following inbound connections.
Port number |
Protocol |
Process |
Connections from... |
Purpose |
| 80 |
HTTP |
IIS |
XProtect Smart Client and the Management Client |
The purpose of port 80 and port 443 is the same. However, which port the VMS uses depends on whether you have used certificates to secure the communication.
| 443 |
HTTPS |
IIS |
For an overview of all the ports that the VMS uses, see Ports used by the system.
