Change the language
You can change the language of the Milestone Customer Dashboard interface and system reports. To change the language:
  1. In the upper right-hand corner, select your login name, then select User settings.
  2. On the User settings page, under Language and region, select the desired language in the Language list.
  3. Select Save to apply the changes.
