Register software license codes (SLCs)
If you register a software license code (SLC) in Milestone Customer Dashboard, you can:
- Track the licenses that you sell to customers.
- Assign licenses to customers.
- Set up monitoring of your customers' VMS installations.
Distributor, resellers, integrators and end-users can all register licenses. Each role can only register a license once.
To register an SLC:
- Log in to Milestone Customer Dashboard (https://online.milestonesys.com/).
In the main menu, select Licenses or Customers
, then select Register new license (SLC)
. - In the Register new license window, in the License code (SLC) field, enter the SLC
. - In the MAC address of the server that was used for activation field, enter the MAC address of the server that you used to activate the license on
Click Next
- Optional: In the License group field, assign the SLC to an existing license group
. - Optional: In the License description field, enter a custom description of the license
.You can search by license description on the Licenses page in the Search field.
- To associate the SLC with a customer
For an existing customer, select a customer in the Customer list
For a customer that has not yet been created in Milestone Customer Dashboard, select Add customer, enter a new customer name, and select Save
Select Register SLC
. The new license is added to the Licenses list.
Only distributors, resellers and integrators can associate SLCs with customers.
