Troubleshooting Milestone XProtect VMS video driver
Video Driver logs are controlled by the settings available in the following config file:
ACVS.Enterprise.Server.Configuration.exe.config
The file location:
C:\Program Files (x86) \Tyco\CrossFire
File location (in an upgraded system):
C:\Program Files (x86)\Software House\SWHSystem\CrossFire
The config file can be edited to contain this setting:
<appSettings>
<add key = “TraceViewer.Enable” value=”true”/>
</appSettings>
The value parameter can be set to true or false to enable or disable logging.
Open the Server Configuration Application in CCure 9000. Select the Diagnostics tab. Click on Connect. Several modules appear. Select MileTraceSwitch and set the trace value.
Red for Error
Yellow for Warning
Purple for Info
Green for Verbose
