Milestone camera and Recording Server alarms (explained)
You can use all camera and recorder alarms in the CCure 9000 system with the XProtect Video Push integration. Alarms are available in the individual camera or recorder configuration windows in the Administration Station application. To do this:
  1. From the Video menu. double click on any Recording Server or camera
  2. Go to the Alarms tab in the configuration window, then open the Property list to view the full list of alarms.
  3. There are 48 different recorder alarms and 115 different camera alarms.
