The webhooks API
This overview of the XProtect webhooks API is based on the Webhooks API, version 1.0.
The HTTP POST object consists of a header and the body (payload).
HTTP POST Body (version 1.0)
The payload of the HTTP POST is an application/json object with the following keys:
| Key | Type | Description |
| Event | BaseEvent (serialized to JSON) | The event that triggered the rule. |
| Site |
Copy
Information about the system where this event originated. Use this field when using the same webhook endpoint for multiple XProtect installations. |
"Event": {
"EventHeader": {
"ID": "2388f93d-5cb0-48e0-9524-d8bb981e1629",
"Timestamp": "2022-11-26T15:59:39.2988877Z",
"Type": "System Event",
"Version": "1.0",
"Priority": 1,
"PriorityName": "High",
"Name": "External Event",
"Message": "External Event",
"Source": {
"Name": "Event High",
"FQID": {
"ServerId": {
"Type": "XPCO",
"Hostname": "ec2amaz-111k11j",
"Port": 80,
"Id": "2f04e7ee-2ee2-49d4-8415-de28dba7ef2e",
"Scheme": "http"
"ParentId": "2f04e7ee-2ee2-49d4-8415-de28dba7ef2e",
"ObjectId": "13860010-ded3-42ff-a2a9-cc6ba4a49636",
"FolderType": 0,
"Kind": "c9bdac3f-41dc-4afa-b057-61767a3914b7"
"MessageId": "0fcb1955-0e80-4fd4-a78a-db47ee89700c"
"Site": {
"ServerHostname": "ec2amaz-111k11j",
"AbsoluteUri": "http://ec2amaz-111k22j/",
"ServerType": "XPCO"
HTTP POST Headers
The HTTP POST headers contains the following keys:
| X-Milestone-Api-Version | String | The version of the body. “v1.0” is currently the only supported version. |
| X-Hub-Signature-256 | String |
The HMAC hex digest using SHA-256 of the body. The value always starts with “sha256=”. For more information, see “Improving webhook security with tokens”. |
"X-Hub-Signature-256": "sha256=LBr6+XIEOZKgMck2/aG1CNCaCCOAwHT4o+vYRE4D3JM=",
"X-Milestone-Api-Version": "v1.0",
"content-type": "application/json; charset=utf-8"
Failed requests and retry policy
If the POST requests fails with a 400 error, it is not retried again.
If the POST requests fails with any other status code, or a timeout, the request will be retried 2 more times, with each attempt spaced 30 seconds apart.
The same "Event.EventHeader.ID from the original HTTP POST Body will be used in all retries so the subscribing/receiving service can track any potential duplicate event notifications.
