Uninstalling from computer
The following procedure describes standard system component removal in recent Windows versions. The procedure may be slightly different in older Windows versions.
- In Windows' Start menu, select Control Panel, and:
- If using Category view, find the Programs category, and click Uninstall a program
- If using Small icons or Large icons view, select Programs and Features
- In the list of currently installed programs, right-click the required Milestone program or service.
- Select Uninstall if you wish to uninstall all components. Select Change if you only wish to uninstall some components.
- Follow the removal instructions.
