View LPR server information
To check the state of your LPR servers:
                                    In the Site Navigation pane > Servers, select LPR servers. In the LPR server information window, see an overview of all installed LPR servers and their name, host name, and status.
                                    Select an LPR server. In the LPR server information window, see details about the server.
LPR server information properties
| Field | Description |
| Name | Here you can change the name of the LPR server. |
| Host name | Shows the LPR server host name. The first part of the name of the LPR server consists of the name of the host computer for your LPR server installation. Example: MYHOST.domainname.country. |
| Status | Shows the status of the LPR server. If the server has just been added, the status is:
 If the system is running without problems, the status is:
 Alternatively, the system returns:
| Service up time | Shows the up time since the LPR server was last down and the LPR Server service started. |
| Computer CPU usage | Shows the current CPU usage on the entire computer with the LPR server(s) installed. |
| Memory available | Shows how much memory is available on the LPR server. |
| Recognized license plates | Shows the number of license plates that the LPR server has recognized in this session. |
| LPR cameras | Shows a list of enabled LPR cameras that run on the LPR server and their status. |
| LPR cameras available | Based on your license, this number shows how many additional LPR cameras you are allowed to add and use on all your LPR servers in total. |
| Country modules available | Based on your license, this number shows how many additional country modules you are allowed to use on all your LPR servers in total. It also lists the number of country modules already in use. |
