View LPR recognitions
You can view LPR recognitions in the alarm list. If you select events as the data source, all recognitions are displayed. If you select alarms as the data source, only the recognitions associated with an alarm are displayed.
  1. Go to the Alarm Manager tab.
  2. Click the Setup button to enter setup mode.
  3. To view recognitions associated with an alarm:
    1. In the Data Source list, select Alarm.
    2. Select Setup again to exit setup mode and save your changes. The recognitions are displayed in the alarm list.
    3. To view incoming LPR alarms, enter LPR in the Type field.
      View license plate recognitions in XProtect Smart Client.
  4. To view all recognitions:
    1. In the Data Source list, select Event.
    3. To view all incoming LPR events, enter LPR in the Type field.
The alarm list will display the filtered results only when you leave the field you modified.
