Uninstall XProtect LPR
If you want to remove XProtect LPR from your system, uninstall the two components separately using the regular Windows removal procedure:
  • On the computers where the XProtect LPR plug-in is installed, uninstall Milestone XProtect LPR [version] Plug-in
  • On the computers where the XProtect LPR server is installed, uninstall Milestone XProtect LPR [version] Server.
