XProtect Access and XProtect Mobile (explained)
The use of XProtect Access requires that you have purchased a base license that enables you to access this feature within your XProtect system. You also need an access control door license for each door you want to control.
With XProtect Access and the XProtect Mobile app installed on your smartphone or tablet, you get:
  • Live monitoring of events at access points
  • Operator aided passage for access requests
  • Investigation of events at access points
  • Centralized overview and control of door states
  • Cardholder information
Access requests
When you get an access request on your device, it may look like this:
Access requests let you:
  • View the state of the door, for example, Closed, Locked.
  • View live video.
  • View the cardholder details, for example, picture and authority level.
  • Lock doors and grant access to cardholders by unlocking doors.
  • Listen to incoming audio in live mode.
  • Use the push-to-talk (PTT) feature while you are watching live video from one camera.
Access requests are listed under Access requests for two minutes. After that, they appear only in the Events list, where you can watch the video recorded when the cardholder tried to gain access.
