Uninstall the AXIS A1001 plug-in
On the computer that hosts your XProtect Event Server:
  1. In Management Client or Management Application, delete all AXIS A1001 plug-in integrations.
  2. In Windows 10:
    1. Select the Start menu.
    2. Select Settings.
    3. Select Apps. You will see a list of all installed apps.
    4. Find and select XProtect Access AXIS A1001 Network Door Controller Plug-in.
    5. Select Uninstall.
    6. Follow the on-screen instructions to uninstall the AXIS A1001 plug-in.
