Configure access requests
There are several types of access control events, for example Access denied and Access granted. To enable access requests notifications, you must associate the type of event with the event category Access request. By default, Access denied is associated with Access request: Access request notifications are sent only when someone is denied access. To change this setting, follow the steps in this topic.
Requirements: On the roles of the client users, you must enable notifications. To do this, on the role, click the Access Control tab, select Access Control, and then select the Receive notifications check box.
Steps:
  1. In the Site Navigation pane, select Access Control.
  2. On the Access Control Events tab, in the Access Control Event column, locate the event type that you want to edit.
  3. To disable access requests for an event type, in the Event Category column, click and clear the Access request check box.
  4. To enable access requests for an additional event type, in the Event Category column, click and select the Access request check box.
  5. Save the changes.
