Export as still images
Click here to download poster.
The following steps are the last steps you need to complete to export video. At this point, you have already added video sequences to the export list and perfected the content for export.
Export a still image for each frame of each video sequence in JPEGLukket En billedkomprimeringsmetode, også kendt som JPG eller Joint Photographic Experts Group. Metoden er en såkaldt lossy-komprimering, hvilket betyder, at nogle detaljer fjernes i billedet ved komprimering. Billeder der komprimeres på denne måde kaldes for JPG- eller JPEG-billeder. format.
Choosing this format can be relevant if you only need to provide still images as evidence in the exported file.
Steps Action
Select the export format.
Choose whether or not you want to include timestamps.
Start the export.
Give the export a name, add a comment, and choose where to save the export. Select Export.
SC_PPP_ExportStillImages_en-US.pdf
