Copy a view or view group
You can copy a view or a group with all its views and paste them to another place on the Views pane.
If you have permissions, you can also copy a private view to a shared view group, making it available to more users.
  1. Na panelu nástrojů pracovního prostoru vyberte možnost Nastavení.
  2. Select the view or group you want to copy.
  3. At the bottom of the Views pane, select Copy , or press CTRL+C.
  4. Browse to where you want to paste the view, select Paste , or press CTRL+V.
  5. To rename the copied view or group, right-click it and select Rename .
