Milestone Husky IVO 700R revision 3
Set the time zone, date, and time
Versionrev3
LanguageEnglish
When you have completed the installation of your Windows operating system, you must change the time zone from the default to the time zone in which the Husky unit will be deployed.
You must also update the machine date and time from the default date and time.
Note
You must have administrator privileges to change the date and time settings.
Update the unit's date and time settings
  1. On the Husky unit, press Windows+R to open the RUN box.
  2. In the RUN box, type "TimeDate.cpl" and press Enter to open the Set the time and date form.
    You must provide your administrator password before you can access the form.
  3. In the Set the time and date form, update the date, time, and time zone of the Husky unit.
