BriefCam VMS Integration Guide
Motorola Solutions Avigilon Integration
Last Updated: 3 minute read
LanguageEnglish
Integration Summary
VMS Partner
Product
Version
Last Tested BriefCam Version
Integration Level
H.265 Support
Motorola Solutions
Avigilon Unity
8.7
2025 R1 SP1
Integration for on-demand and real-time (L2)
No
Motorola Solutions
Avigilon Control Center
7.14
2024 R2 HF4
No
Motorola Solutions
7.12
2023 M1
No
VMS SDK
  1. Prior to the plugin installation, install the relevant Avigilon SDK.
    • For Avigilon 7.12 and 7.14, you need SDK version 6.14.22.6.
    • For Avigilon Unity 8.7, BriefCam is using the WebEndpoint API instead of the VMS SDK. Therefore, no SDK installation is required.
  2. Install the Avigilon SDK on the BriefCam server.
  3. If the On-Demand processing server and/or Real-Time processing server is installed on a dedicated machine, also install the Avigilon SDK on the On-Demand processing server and/or Real-Time processing server.
Post-Installation Step for BriefCam 2025 R1 SP1
After installing the Avigilon plugin, you need to replace the installed BriefCam.VideoNative.dll file with a newer version.
  1. Download the newest version of the file by clicking here.
  2. Unzip the downloaded file.
  3. Copy the new BriefCam.VideoNative.dll file and save it to: BriefCamServerInstallationFolder/plugins. When prompted, allow it to replace the existing file.
  4. Restart all BriefCam services.
Known Limitations
  • For L1 integrations, the VMS supports fetching only one file at a time, which may result in slower retrieval performance. Therefore, it is recommended to reduce the fetching workers by changing the Fetching.NumberOfWorkers environment setting from 2 to 1.
  • Motion cameras are not fully supported, as we currently have no reliable way to determine the actual time within the exported video. This results in incorrect timestamps being displayed to the user.
  • In Avigilon Control Center (ACC 7.12 and/or 7.14) integrations, slow processing was observed when working with 4K cameras. This is because of slow decoding due to the proprietary format.
  • In Avigilon Control Center (ACC 7.12 and/or 7.14) on-demand scenarios:
    • Although the processing is reported to be completed successfully, occasional frames may be dropped and indicated in the logs.
    • In certain scenarios, the fetching of videos is slow. To solve this issue, define additional parallel workers or reduce the camera resolution. For additional information, see the Recommended Configuration section above.
  • Support for the H.265 format is done per request. If you want to use the H.265 format with this VMS, please contact BriefCam's support.
See also: VMS Integration IssuesVMS Integration Issues
