BriefCam VMS Integration Guide
Hexagon Qognify Nicevision Integration
LanguageEnglish
Integration Summary
VMS Partner
Product
Version
Last Tested BriefCam Version
Integration Level
H.265 Support
Hexagon
NiceVision Qognify SVR
3.2 UP2
2024 R2 HF4
Integration for on-demand and real-time (L2)
Yes
Hexagon
3.2 UP2
2023 M1 (Next-Gen engine)
No
Ports Required
The following ports should be available when installing the plugin:
Port #
80, 500, 2001, 2011, and 50000
VMS SDK
Prior to plugin installation, make sure you have the required Qognify SDK installed on the BriefCam Server.
  • For NiceVision 3.1 you need PlayerComponent Package_12.1.0.147.exe.
  • For NiceVision 3.2 you need PlayerComponent Package_12.2.0.133.exe.
  • For NiceVision 3.2 UP2 you need PlayerComponent Package_12.2.2.193.exe.
The SDK is required to be installed on every machine on which any of the following services is installed: BriefCam Server service, OX6.OnDemand Service, and OX6.RealTime Service.
Integration – Plugin Installation
When installing Qognify NiceVision 3.2, you will be asked to provide the path to the SDK in the Player component path field.
To run a silent installation of the NiceVision plugin, use the following command line:
{ NiceVision Installer file name} /qn APPDIR="C:\Program Files\BriefCam\BriefCam Server\" SDK_PATH="{Path to the NiceVision SDK Player component}"
Known Limitations
  • Support for the H.265 format is done per request. If you want to use the H.265 format with this VMS, please contact BriefCam’s support.
