BriefCam VMS Integration Guide
American Dynamics Integration
LanguageEnglish
Integration Summary
VMS Partner
Product
Version
Last Tested BriefCam Version
Integration Level
H.265 Support
Additional License Required
American Dynamics
VideoEdge
6.3
2024 R2 HF4
Integration for on-demand and real-time (L2)
Yes
A floating license is required for each recorder.
VMS SDK
Prior to the plugin installation, install American Dynamics SDK 5.3.3.
Known Limitations
  • Bounding boxes when playing the original video are not supported.
  • Support for the H.265 format is done per request. If you want to use the H.265 format with this VMS, please contact BriefCam’s support.
  • In American Dynamics integrations, when fetching fails due to a corrupted file in on-demand requests, the decoding partially fails.
