BriefCam User Guide
Sample Workflows
Version2025 R1
LanguageEnglish
Creating a Dashboard
Create a new sheet as explained in Creating a New Sheet (Dashboard), then follow the steps described below.
  1. Drag a Bar chart to the sheet.
  2. Click Add dimension and select Class.
  3. Click Add measure and select # of Objects.
  4. Add a title to the chart.
  5. Change sorting by dragging items on the right-hand menu, so that Class precedes # of Objects.
  6. Expand Class, select Custom sorting and check Sort alphabetically.
  7. Drag a Pie chart onto the dashboard.
  8. Click Add dimension and select Direction Label.
  9. Click Add measure and select # of Road Vehicles.
  10. If you do not see a legend, change Show Legend to Enabled.
  11. Drag the Filters visualization to the dashboard.
  12. Click the Done editing button.
    Congratulations! You’ve created a new dashboard.
Multi-Camera Dashboard
To create a Multi-Camera Dashboard that presents object counts from multiple sources in the same sheet, follow the steps described below:
  1. Drag the KPI chart onto the dashboard.
  2. Select the # of Objects in Specific Source measure.
  3. The result will currently be 0 objects.
  4. Unlink the measure within the visualization object by clicking the unlink (Unlink icon.png) icon.
  5. Click OK.
  6. In the Expression field, click the function (Expression icon.png) button.
  7. Replace the string SourceExample with the requested Source name.
  8. See the result.
Multi-Path, Area, or Line Crossing Dashboard
To create a Multi-Path, Area, or Line Crossing Dashboard that presents object counts from multiple paths/areas/line crossings in the same sheet, follow the steps described below:
  2. Select the # of Objects in Specific Source and Custom Dimensions measure.
  5. Click OK.
  7. Replace the string SourceExample and CustomDimensionsExample with the requested source and custom dimension name.
  8. See the result.
