BriefCam Upgrade Guide
Upgrading from v2023 M1 and Below
Version2025r1
LanguageEnglish
Upgrading from v2023 M1 and below is a two-stage process:
  1. You first need to upgrade to v2024 M1 (following the steps in the v2024 M1 Installation Guide).
  2. Then upgrade again to BriefCam 2025 R1 following the steps in Upgrading from v2024 M1 or Above to v2025 R1.
Note
To upgrade from a version prior to 5.4.1, you will need to wipe the server and reinstall the newer version of BriefCam.
