BriefCam Upgrade Guide
Version2025r1
LanguageEnglish
This section describes how to upgrade your environment to the latest version of BriefCam.
Steps for Upgrading
Upgrading from v2024 M1 or Above to v2025 R1
Upgrading from v2023 M1 and Below
Upgrading a Next-Gen Deployment
General Notes
  • When installing or upgrading BriefCam or upgrading the NVIDIA GPU driver, it takes up to 30 minutes for the Processing Server service or Alert Processing Server service to start for the first time, because the Deep Neural Networks are being rebuilt.
  • As of BriefCam 2025 R1, Redis is removed from the system. After the upgrade, there may be some residual files and registry entries that are left (for example, c:\program files\redis containing logs). This is the expected behavior and can be ignored.
Known Issues
  • When upgrading, if a customer wants to use a custom passphrase, they will have to uninstall and then reinstall the BriefCam Server, Web Services, and VMS plugins.
See also: Silent Installations for Upgrading
