Upgrading from v6.3 and Below
Upgrading from v6.3 and below is a two-stage process:
You first need to upgrade to V6.4 (following the steps in the V6.4 Installation Guide).
Then upgrade again to BriefCam 2024 R2 following the steps in Upgrading from v6.4 or Above to v2024 R2.
Note
To upgrade from a version prior to 5.4.1, you will need to wipe the server and reinstall the newer version of BriefCam.
