BriefCam Troubleshooting Guide
Log Files
Last Updated: 4 minute read
Version2025r1
LanguageEnglish
For troubleshooting purposes, it is important to become familiar with BriefCam’s log files. BriefCam’s log files track both ongoing activity and unexpected errors.
Here are some examples of which log files you would look at depending on the issue:
Issue
Log files to look at
Can’t play any form of video including the VIDEO SYNOPSIS
Rendering, Video Streaming Gateway, and ProWebApi
Processing is stuck or taking too long
Fetching and Processing Server
Web client is not responsive or not displaying properly
ProWebApi
Filtering isn’t working
Filtering and ProWebApi
Face Recognition not working
Face Recognition, Rendering and ProWebApi
Installation Log Files
The installation log files are located at: C:\Users\<USER>\AppData\Roaming\BriefCam where <USER> is the operating system user. If you ran the installer as an administrator (which is the recommendation), the path will be: C:\Users\Admin\AppData\Roaming\BriefCam.
Log Files for BriefCam’s Web Services
The following are log files related to BriefCam's Web services:
The last 250 MB of each day’s log files will be saved for up to 14 days. These default values can be changed using the environment settings as described in the Server-related Log Files section above.
RESEARCH Module Log Files
There are a number of log files related to the RESEARCH module.
RESEARCH Installation Log File
The RESEARCH_Install.log file is located at: C:\Users\<USER>\AppData\Roaming\BriefCam where <USER> is the operating system user. If you ran the installer as an administrator (which is the recommendation), the path will be: C:\Users\Admin\AppData\Roaming\BriefCam.
RESEARCH Service Log File
The RESEARCH Service log file is named BIRuleEngineService and is located at: C:\Program Files\BriefCam\BriefCam Server\logs\BIRuleEngineService-0.
Qlik Log Files
This log file is located at: C:\ProgramData\Qlik\Sense\Log.
Note
ProgramData is a hidden folder.
To minimize the growth of the Qlik trace log folder, continuously back up and remove files that have not been modified for a period of time.
Each element has separate log files, such as Engine and App Migration.
Milestone Embedded Log Files
There are two log files for Milestone Embedded environments.
MilestoneEmbeddedViewer.log, which is located at: ${APPDATA}/Briefcam/Client/logs/. The configuration file for this log is MilestoneEmbeddedViewerLogConfig.xml, which is located at: C:\Program Files\BriefCam\BriefCam Server.
EmbeddedBrowser.log, which is located at: ${APPDATA}/Briefcam/Client/logs/. This log is available if you enable it as follows:
  1. Open the MilestoneEmbeddedViewer.dll.config file, which is located at: C:\Program Files\Milestone\XProtect Smart Client\MIPPlugins\BriefCam.
  2. Set the browserLog value to true.
See also:
Why am I seeing an Npgsql.PostgresException in the VSServer log?
Why am I seeing a System.IO error in the log?
Why am I seeing an Unhandled Exception from Integration error in the log?
Why am I seeing a Shutdown Ended message in the log?
