BriefCam Troubleshooting Guide
Why is it taking the installation a long time to finish?
Version2024r2
LanguageEnglish
If the installer seems to be stuck and it takes 5-20 minutes to finish, it is most likely due to a bug with the HASP driver installer. It should complete eventually. The PostgreSQL installer could take significantly more time to finish than all of the other installers. Let it run for at least 30 minutes before determining that it is stuck.
