BriefCam Troubleshooting Guide
The qlik_migrate tool returned a fail message. What should I do?
Version2024r2
LanguageEnglish
When upgrading to BriefCam 2024 M1, running the qlik_migrate tool is required for environments using RESARCH.
If the qlik_migrate tool fails, do the following:
  1. From the ResearchQvd folder (located by default at: C:/QlikShare), delete the following:
    • BC_BI_SOURCE_MATCH_1 folder
    • BC_BI_SOURCE_MATCH2 folder
    • expected_migration.txt file (if it exists)
  2. Copy the FILES_MAX_TIMESTAMP.qvd file from the C:\Program Files\BriefCam\RESEARCH\ folder and save it to C:\QlikShare\ResearchQVD – replacing the existing one.
  3. Re-run the qlik_migrate tool.
