Installed Prerequisites
The installation checks for the following prerequisites. (BriefCam will install them for you if they do not exist. You do not need to install them manually):
PostgreSQL
Microsoft Visual C++ 2013 Redistributable Package (x64) - 12.0.40649
Microsoft Visual C++ 2015 2017 2019 Redistributable Package (x64) - 14.34.31931
Microsoft .NET Core Runtime - 8.0.8 (x64)
PostgreSQL 15
RabbitMQ
Microsoft Visual C++ 2013 Redistributable (x64) - 12.0.40649
Erlang/OTP 23
RabbitMQ Server
BriefCam Server
Microsoft Visual C++ 2010 SP1 Redistributable Package (x64)
Microsoft Visual C++ 2012 Redistributable Package (x64)
Microsoft .NET Framework 4.7.2 Full
Microsoft .NET 8
Microsoft ASP .NET 8
RESEARCH
BriefcamPostgreSQL_ODBC_Driver
Qlik Sense May 2024
Qlik Sense May 2024 Patch 11
Web Services
Microsoft IIS Installer for BriefCam Web Services
Microsoft .NET 8
IIS URL Rewrite
Milestone Embedded Client
Genetec Security Center Embedded Client
