BriefCam Installation Guide
Installed Prerequisites
Version2025r1
LanguageEnglish
The installation checks for the following prerequisites. (BriefCam will install them for you if they do not exist. You do not need to install them manually):
PostgreSQL
  • Microsoft Visual C++ 2013 Redistributable Package (x64) - 12.0.40649
  • Microsoft Visual C++ 2015 2017 2019 Redistributable Package (x64) - 14.34.31931
  • Microsoft .NET Core Runtime - 3.1.0 (x64)
  • PostgreSQL 15
RabbitMQ
  • Microsoft Visual C++ 2013 Redistributable (x64) - 12.0.40649
  • Erlang/OTP 23
  • RabbitMQ Server
BriefCam Server
  • Microsoft Visual C++ 2010 SP1 Redistributable Package (x64)
  • Microsoft Visual C++ 2012 Redistributable Package (x64)
  • Microsoft .NET Framework 4.7.2 Full
  • Microsoft .NET 8
  • Microsoft ASP .NET 8
RESEARCH
  • BriefcamPostgreSQL_ODBC_Driver
  • Qlik Sense May 2024
  • Qlik Sense May 2024 Patch 11
Web Services
  • Microsoft IIS Installer for BriefCam Web Services
  • Microsoft .NET 8
  • IIS URL Rewrite
Milestone Embedded Client
Genetec Security Center Embedded Client
