BriefCam Installation Guide
Firewall Consideration and Ports Availability
Version2025r1
LanguageEnglish
Internal (Local) Ports
On each server, the following ports should be opened for internal communication:
  • On each server, all outbound ports should be opened, to allow communicating with other servers as needed.
  • On each server, the following inbound ports should be opened according to the installed services. The BriefCam application listens for incoming traffic from these ports. The installer will create the relevant Windows firewall rules for these ports.
Component
Port #
BI Face Recognition Service
TCP 2556, TCP 13004
Face Recognition Matching Service
TCP 2553, TCP 13002
Filtering Service
TCP 2555, TCP 13001
License Service
TCP 1947
Lighthouse Service
TCP 2557
LPR Matching Service
TCP 2554, TCP 13003
MilestoneSSOProvider
TCP 8030
Notification Service
TCP 7080
PostgreSQL
TCP 5432
Rabbit MQ
TCP 5672, TCP 15672
Storage
TCP 139, TCP 445
Storage Gateway Service
TCP 5012
Video Streaming Gateway Service
TCP 5010
VSServer Service
TCP 1112, TCP 1113
Web Services (BOA, ProWebApi, AdminWebApi)
HTTP (80)
Hub
BI Hub Export Gateway
TCP 5007
Outbound API Gateway
TCP 5005
Hub SSO Gateway (for future versions)
TCP 5008
RESEARCH (BI) Ports
RESEARCH (Qlik)
Port #
HTTP
TCP 8090
Inbound / Outbound
HTTPS
TCP 443
Inbound / Outbound
API ports
TCP 4242, TCP 4243
Inbound / Outbound
Qlik Sense Engine Service
TCP 4747
Inbound / Outbound
Broker Service
TCP 4900
Inbound / Outbound
Qlik Sense Repository Database (QRD)
TCP 4432
Inbound
Qlik Sense Printing Service (QPR Listen Port)
TCP 4899
Inbound / Outbound
Qlik Sense Logging Service
TCP 7070
Outbound
License Service
TCP 9200
Outbound
External Ports
Note
The following ports should be opened to traffic coming from the end users’ browsers.
Component
Port #
Comment
Web Services
HTTP (80)
RESEARCH
HTTP (8090)
Not needed when using a load balancer
TCP 5010
TCP 7080
TCP 5012
To work with HTTPS and port 443, you need to use a load balancer. For more information, see Installing and Configuring NGINX.
Note
Some ports can be changed if they are not allowed on the customer’s network. For detailed instructions, see Changing Default Ports Configuration.
