BriefCam Installation Guide
Logging and Monitoring
Version2024r2
LanguageEnglish
When deploying a large scale system, there is a need to monitor the system and the logs from a single place. For this purpose, BriefCam recommends working with the following:
The above components are deployed separately on a dedicated Linux instance.
For additional information about running the Prometheus and Grafana scripts, contact BriefCam Support.
