Logging and Monitoring
When deploying a large scale system, there is a need to monitor the system and the logs from a single place. For this purpose, BriefCam recommends working with the following:
Prometheus® and Grafana technology for large scale monitoring and monitoring dashboards.
The above components are deployed separately on a dedicated Linux instance.
For additional information about running the Prometheus and Grafana scripts, contact BriefCam Support.
