Load Balancers
To serve a large number of users or real-time channels simultaneously, you can deploy multiple instances of web services behind a load balancer. The load balancer will distribute the traffic efficiently and will enable both scaling and high availability. For this purpose, BriefCam recommends working with the NGINX load balancer.
For additional information, see Installing and Configuring NGINX.
