BriefCam Installation Guide
Distributed Architecture
Version2024r2
LanguageEnglish
All BriefCam components can be installed on one machine (all-in-one) or the components can be distributed across several machines.
In general, to ensure a fast, real-time user experience with high capacity loads, use dedicated machines for the following components: Rendering, RESEARCH, Database, Storage and Processing Servers.
For example, if your deployment is RESEARCH-focused, install the RESEARCH component on a separate machine.
For additional information, see the BriefCam High Availability Deployment White Paper.BriefCam High Availability Deployment White Paper
See also the Required Configuration per Machine Type section.
