BriefCam Installation Guide
Configure Server Logging Tool
Version2024r2
LanguageEnglish
This tool lets you update the configuration of the BriefCam Server's log files (Logconfig.xml) from one location.
The tool can be found at: {BriefCam Server installation folder}\tools\log_configuration_tool.
This tool includes a config.json file that lists all the appenders and elements to be updated. When it runs on the target machine it discovers the location where the BriefCam Server was installed and replaces the values according to the config file.
To run this tool:
  1. Copy both the configure.ps1 and config.json files to the target machine.
  2. Update the config.json file with the changes that you want to make to the log configuration files.
  3. Open PowerShell as an administrator.
  4. Run the configure.ps1 file.
