Server Hostname Change Tool
This tool makes changes to an all-in-one environment after a server hostname change. Note that this tool does not make changes to the RESEARCH component or to RabbitMQ.
Note
Note: It is highly recommended not to change the server hostname if you are using the RESEARCH component.
The tool (BriefCamUpdateHostname) is available at: {BriefCam Server installation folder}\tools\change_hostname.
To work with the tool:
Change the machine’s host name. (Make a note of the original host name because you will need it in step 4.)
Restart the machine.
Reshare the BriefCam share.
Open PowerShell as admin.
Run the following command:
.\update_hostname.exe /qn NEW_HOSTNAME="{the new host name}" OLD_HOSTNAME="{the old host name}" POSTGRES_BC_USER="{the BC application user for connecting to the DB}" POSTGRES_BC_PASSWORD="{the password for BC application user}" LOG_NAME="{the file name for the application log}" /L*V "{path for verbose logging of the tool}"The
LOG_NAMEparameter controls the name of the log the tool generates for tracking what was changed. This log is saved in the%APPDATA%\briefcamfolder.The machine will be restarted by the installer after the tool has finished running.
Uninstall RabbitMQ using the Windows Add/Remove Programs option.
Reinstall the RabbitMQ component.
