BriefCam Installation Guide
Activating a Custom License in Qlik Sense
Version2024r2
LanguageEnglish
  1. Log in to the Qlik Management Console (QMC) at: https://localhost/qmc.
  2. Sign in using the bcuser account.
  3. Navigate to: Manage Resources → License Management.
  4. From the right-side menu, select Site License.
  5. Enter the license information provided to you:
    • Owner Name: Research
    • Owner Organization: Research
    • Serial Number:  <Custom serial number>
    • Control Number: <Custom control number>
  6. Paste the provided LEF into the LEF text box. You can get a LEF token by using this web page: Manual LEF (qliktech.com). If you need assistance with this, please contact BriefCam’s support.
    • Ensure the LEF is copied exactly as provided.
    • Avoid leading/trailing spaces or extra line breaks.
  7. Click Apply to activate the license.
  8. Verify the license activation:
    • Navigate to License Usage Summary.
    • Confirm that the available number of licensed users matches the quantity purchased with the custom license.
