BriefCam Administrator Guide
Size Settings
Version2025 R1
LanguageEnglish
Case Size Settings
As of BriefCam v2025 R1 SP4, cases that contain over 300,000 objects are marked as Large and cases that contain over one million objects are marked as Oversized.
The limits can be changed using the ObjectsPerLargeCase and MaxObjectsPerCase environment settings. Note that increasing the numbers may cause performance issues or system failure if the system is not robust enough to support the higher numbers.
